It is currently Fri Aug 08, 2025 3:42 am
PostPosted: Mon Jun 29, 2009 9:13 am
The newest Luthier Tips du Jour instructional video is on Youtube. The topic is the bolt on mortise and tenon neck joint. Subtitles are available in both English and Portuguese and you can translate them into any other language by using the CC option on Youtube.
As always, comments and discussion are welcome.
Enjoy!
PostPosted: Mon Jun 29, 2009 9:48 am
First name: Jim
Last Name: Hansen
Nice work Robbie!
Thanks so much for doing this...
Is the next video going to be how to build a set of M/T jigs? :D :lol:
Jim Hansen
PostPosted: Mon Jun 29, 2009 9:59 am
Nice video, as always, Robbie! Your presentations get more professional with each new chapter! Thanks for posting.
The neck tenon routing jig that you highlight (AKA Woolson Neck Tenon Jig) has a great construction drawing that used to be available for purchase here at the OLF. Check with Lance or Michael Payne for more details. It's a great jig and well worth building if you build your own necks and plan to build more than one guitar.
PostPosted: Mon Jun 29, 2009 10:06 am
Last Name: Hodge
Mr. O'Brien does it again. Great work Robbie thanks! :D
Bill Hodge
PostPosted: Mon Jun 29, 2009 10:09 am
Thank you Jim and JJ.
I have been using a version of this jig for years and within the last few years added the metal rod part of the jig after seeing the Woolson Jig. I always get emails from people asking about plans and didn't know any plans existed anywhere. If someone knows about a set of plans please let me know so I can pass this info on.
PostPosted: Mon Jun 29, 2009 12:03 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Another great video Robbie, you make getting building info much easier. I wish I was beginning now instead of 4 years ago, I would have avoided a lot of extra web searching and mistake corrections.
I also am interested in plans if they are still available.
Fred
Fred Tellier
PostPosted: Mon Jun 29, 2009 1:07 pm
First name: Adam
Last Name: Yavner
City: Wylie
Zip/Postal Code: 75098
hehe: "tighten the jig until you hear a crack, then back off a quarter turn".
Sheer gold, man... priceless.
Thanks!
adam
"Everyone wants to BE something, but nobody wants to BECOME something" - William Cumpiano
PostPosted: Mon Jun 29, 2009 2:47 pm
First name: Randolph
Last Name: Morris
Robbie, Fabulous as always. They just keep getting better and better! This one, in particular with the jigs is a huge help on a fairly daunting area (neck angle). I assume the next video will be on body crack repair after backing off jig tension? laughing6-hehe
PostPosted: Tue Jun 30, 2009 8:16 am
First name: Ron
Last Name: Senf
City: Muskegon
Zip/Postal Code: 49445
Robbie, your jig looks a lot better than the one on your dvd (you complained about the dust shooting back on your face) I got from LMI a few years ago. I use StewMac templates and built a similar fixture with their plans. Great video.
BTW, I use brass thread inserts instead of barrel nuts. Does one have an advantage over another?
PostPosted: Tue Jun 30, 2009 9:34 am
The design is the same as the jig used in my dvd. This is just another jig that was actually put together as a prototype of my jig by Tracy Leveque from Luthier Suppliers. Perhaps he could be talked into putting it into production.
When you say you are using threaded inserts I assume you are screwing them into the end grain rather than through the grain like the barrel nuts. Both methods will work but I prefer the cross grain inserts.
PostPosted: Tue Jun 30, 2009 12:56 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Robbie
Excellent info on all of these! Thanks
One question - So how do you deal with the gap under the fingerboard extension above the soundhole, or is that a separate video??
John Ressler
PostPosted: Tue Jun 30, 2009 1:38 pm
First name: Adam
Last Name: Yavner
City: Wylie
JRessler wrote:
Robbie
Clamp it till you hear a crack, then back off... laughing6-hehe laughing6-hehe
PostPosted: Tue Jun 30, 2009 7:45 pm
JRessler wrote:
Robbie
Thanks John.
If I understand your question, the gap is due to the neck angle. I adjust the shelf of my jig to find the correct neck angle and then cut the tenon.
PostPosted: Tue Jun 30, 2009 8:21 pm
First name: Adam
Last Name: Yavner
City: Wylie
Hey guys, don't forget.... we all wanna see more and more of these, so take a sec and make a donation if you are able! It's over at obrienguitars.com home page.
PostPosted: Thu Jul 02, 2009 8:33 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Hi Robbie, just curious how does the plate the holds the rod and the rough neck pivot?
Richard
PostPosted: Thu Jul 02, 2009 9:27 am
Richard
It is attached to the upper deck by a couple of hinges.
PostPosted: Thu Jul 02, 2009 10:05 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Thanks Robbie
PostPosted: Fri Jul 03, 2009 4:10 am
First name: Aaron
I've been working through a M&T bolt-on in my mind for a while (as in over the past 5 or 6 builds). This is probably the closest I've been without actually drawing out a plan to start cutting the jig.
Thank you.
Aaron
PostPosted: Mon Jul 06, 2009 10:29 am
Nice video Robbie and helpful. You now need a hole template fixture. :D
PostPosted: Tue Jul 07, 2009 11:38 am
I don't think this is the place for that. You aren't sending donation to everyone else who shares their knowledge on this and other forums.
Edit
If you remove the following post then remove this one too.
Last edited by Chris Paulick on Tue Jul 07, 2009 12:36 pm, edited 2 times in total.
PostPosted: Tue Jul 07, 2009 11:44 am
First name: Adam
Last Name: Yavner
City: Wylie
Ahhh.. you're probably right, if the mods agree, please remove. Didn't mean to offend.
adam
